Help  Constant fluid flow
Hello!
Is there a way to make fluid move constantly in specific direction or not change its velocity in its life time duration?
(24-02-2021, 08:22 AM)Kyiba Wrote: Hello!
That would basically bypass the fluid simulation, so I'm not sure why you'd want to do this but yes: you can simply constraint the velocity of each particle in any way you need.
To access particle velocities, use the particle API:
(24-02-2021, 08:37 AM)josemendez Wrote: That would basically bypass the fluid simulation, so I'm not sure why you'd want to do this but yes: you can simply  constraint the velocity of each particle in any way you need.
 Thank you, in short its for game where i need fluid to constantly move through pipes that are "flat"
