Help  How to change gravity in script during runtime?
I've just gotten Obi Fluid, and after a lot of experimenting and tinkering, managed to get it to work reasonably well in a Unity project I'm working on. Really cool! However, I would like to/need to be able to change the X and Y gravity Obi Solver settings in script during runtime, but don't see how this is done. I've been looking at the API docs and haven't found what I would need in order to accomplish this. I'm using Unity 2020 and C#.
Any help is appreciated!
solver.parameters.gravity = <your gravity>
solver.UpdateParameters();
Cheers!
Cheers!
Hi. I've a problem...
Solver.UpdateParameters() doesn't exist...
(02-05-2021, 09:32 PM)Ed_looping Wrote: Hi. I've a problem...
If you look at the API docs, you’ll see it has been renamed to PushSolverParameters() in newer versions.
Cheers!
(03-05-2021, 08:05 AM)josemendez Wrote: If you look at the API docs, you’ll see it has been renamed to PushSolverParameters() in newer versions.
Cheers!
Thx Sonrisa
