Help  I want to create an event when clothes touch a particular object.
I tried using http://obi.virtualmethodstudio.com/tutor...sions.html, but I wanted to find an easier way.
So, I'm trying to contact using obicontacteventdispatcher.
(Enter/Stay/Exit) works satisfactorily and satisfactorily.
But what I want is to operate it when a particular collider touches it.
For example, typically in Unity,
private void OnTriggerEnter(Collider other)
          if (other.gameObject.name == "testModel")
               //func();
In this way, only objects named "testModel" can be contacted, but I tried many things using obicontacteventdispatcher, but I couldn't. Could you tell me how to contact only certain objects?
Thank you for your quick response.
In Obi this is done exactly the same way, once you have a reference to the collider involved in the collision, you just check its name (or layer, tag, etc). You can get a reference to the collider from a contact as explained in the manual:
Quote:ObiColliderBase collider = ObiColliderWorld.GetInstance().colliderHandles[contact.other].owner;
Putting it all together:
using UnityEngine;
using Obi;
public class ContactWithNamedObject : MonoBehaviour
    public void OnContactEnterProcess(ObiSolver solver, Oni.Contact contact)
        ObiColliderBase other = ObiColliderWorld.GetInstance().colliderHandles[contact.other].owner;
            Debug.Log("Collision!");
Then you just have to subscribe the OnContactEnterProcess function to the OnContactEnter event of the dispatcher. You can do this trough the inspector, or programmatically.
(21-01-2021, 09:09 AM)josemendez Wrote: In Obi this is done exactly the same way, once you have a reference to the collider involved in the collision, you just check its name (or layer, tag, etc). You can get a reference to the collider from a contact as explained in the manual:
using UnityEngine;
using Obi;
Wow... it's applied so perfectly well. Thank you very much!
