Hi. I am using obi-cloth now. Thank you for making a good eset.
But I want to make the function I want, but it doesn't work. I'd like to ask you a few questions.
What I want is simply that I can grab the stiff cloth myself and want to tear it if I pull it with constant force.
First,
I want to make the fabric quite stiff. Now, I've adjusted the band, distance, and gravity values in Obi Solver's Constraints to some extent.
But it's moving like a cloth. The value I set is as below.
Obi Solver->
Damping 0.99
Obi Solver Constraints ->
Distance - Evaluation : Sequential, Iterations : 20, Relaxation : 1.
Bending - Evaluation : Parallel, Iterations : 15, Relaxation : 1
Collision - Evaluation : Parallel, iterations : 20, Relaxation : 1
Everything else is disabled.
Obi Tearable Cloth is the same as the default setting. I wonder how I can make it more stiff.
second,
I want to simplify the fabric's drooping. If I pull with a certain force, I want to tear it apart.
I made it using CollisionEventHandler of Collision callbacks, and ObiContactGrabber for this.
Obi Tearable Cloth setting->
Tear Compliance : 5000
Tear rate : 1
Tear debilitation : 0
It's easy to get caught, but... I think it's so easy to tear the fabric because I focused on one unit of fabric.
Can you tell me how to correct it?
third.
Too much cloth makes too much crumbs. I want to know how to tear it in that direction if there is a tear side.
Please give me a good answer. Thank you!
![Exclamación Exclamación](https://obi.virtualmethodstudio.com/forum/images/smilies/exclamation.png)
Obi Solver->
Damping 0.99
Tear rate : 1
