Help  problem of particle position
Hi bro.
I make a rope and move it in runtime.
Now,i want to get some particles world position but i failed.
I use
actorIndex = rope.blueprint.groups[0].particleIndices[0]
to get actor index of this particle.
And i use
solverIndex = actor.solverIndices[actorIndex]
to get solver index of this particle
Finally,i use
position = actor.GetParticlePosition(solverIndex);
to get world position of this particle
Problem is this position is not change when i move rope, so i think maybe it is a local position.
Could you help me to get world position of particle?
Think you,waiting for you repose.
Works fine for me, using the exact same code you posted:
using UnityEngine;
using Obi;
[RequireComponent(typeof(ObiActor))]
public class GetCPPosition : MonoBehaviour
    ObiActor actor;
    public int cpIndex = 0;
    void Start()
        actor = GetComponent<ObiActor>();
    private void OnValidate()
        cpIndex = Mathf.Max(0, cpIndex);
    void OnDrawGizmos()
        if (actor != null &&
            actor.blueprint != null &&
            actor.blueprint.groups.Count > cpIndex &&
            actor.blueprint.groups[cpIndex].particleIndices.Count > 0)
            int actorIndex = actor.blueprint.groups[cpIndex].particleIndices[0];
            int solverIndex = actor.solverIndices[actorIndex];
            Gizmos.DrawSphere(actor.GetParticlePosition(solverIndex), 0.5f);
Hi,it ‘s me
Is the particle's world position are calculated by   rope.gameObject.transform?
Because I use particleAttachment connect a particle group to the rope self, i move rope's position to move particles
set like this:
rope.GetComponents<ObiParticleAttachment>()[0].target = rope.gameObject.transform;
rope.GetComponents<ObiParticleAttachment>()[0].particleGroup = blueprint.groups[0];
move like this:
Vector3 to_new_position = new Vector3(0.0f, 0.0f, 1.0f);
rope.gameObject.transform.Translate(to_new_position, Space.World);
(23-12-2020, 03:04 PM)FZMv587 Wrote: Hi,it ‘s me
set like this:
move like this:
Particles are simulated in solver space. To convert to world-space, they're transformed using the solver's transform.
When you attach a particle to a target transform, the particle position at the time of setting the attachment's target/particleGroup is stored expressed in the target's local space. At runtime, this target-space position is converted to solver space and used to set the particle's position. Hope this makes sense!
