Help  Cloth scripted particle attachment in runtime
I am trying to simulate cloth manipulation in Unity 2019.6.16 and Obi Cloth 5.
Currently, I am attaching a sphere to a particle group on the cloth and have written a script allowing me to control the sphere with my mouse (images below).
I want to be able to grasp (click) anywhere on the cloth and manipulate it, and I know there is a better way than creating a few hundred spheres and attaching them individually to each particle in the cloth.
My issue is that I am fairly new to Unity and Obi Cloth, and I am totally stuck on how to script this type of interaction. Specifically, I am not quite sure where to start, should I be modifying the "ObiParticleAttachment.cs" associated with the cloth, or should I create a new .cs file? If I create a new .cs file then how do I access/reference my cloth and its "Obi Particle Attachment" component?
Thanks,
Ben
Hi Ben,
There's a sample component that let you click on any actor and drag it around: ObiParticleDragger.
When you add a ObiParticleDragger, a ObiParticlePicker will also be added as a dependency. The picker raycasts against all particles and raises events for particle click/drag/release. The dragger subscribes to these events and applies spring forces to move the picked particle(s) around.
(17-12-2020, 09:01 AM)josemendez Wrote: Hi Ben,
Hi Jose,
Thanks for the suggestion and the very quick reply, that component is exactly what I was looking for!
Thanks, Ben
