Help  How can i use obi rope in unity with totally script?
Hi,i am new here。
I am a student,in my study i need use a rope model and neural network in the same time。
So i need use obi rope with totally script。
But, i have no idea how to start it。
Is there any example c# code files about how to create a rope,how to change the position ,how to initialize rope in the screen so i can see it ,and so on....
I really need help,thank you。
By the way,i use obi rope 5.6.2
(08-12-2020, 08:49 AM)FZMv587 Wrote: Hi,i am new here。
I don't know what "totally script" is, a quick search in Google does not show any results. Is it any kind of visual scripting?
The manual contains several sections about scripting, with explanations and sample code to create a rope, change any particle properties (positions, velocities, masses), retrieve contact information, etc. See:
http://obi.virtualmethodstudio.com/tutor...ctors.html
(08-12-2020, 10:12 AM)josemendez Wrote: Hi there,
Hi buddy
Thank for you answer me and do not think too much about "totally script", it's just script, i am not good at english, sometimes i have wrong express.
I read the pages you just gave me ,and i try to test those codes , but i meet problem in the beginning.
I update two images, one is my code and another is the error in unity.
I am just copied from " http://obi.virtualmethodstudio.com/tutor...ctors.html ".
Could you help me figure out what is the problem?
Thank you
(08-12-2020, 10:46 AM)FZMv587 Wrote: Hi buddy
Thank you
It's clear you're a beginner with programming. In this case, I strongly suggest to learn some basic C# before attempting to use Obi, as it is aimed at advanced users. Basic programming skills are taken for granted.
The script in your screenshot does not make any sense. The compiler is telling you it did not expect to find a function call directly inside the class, outside of a function definition. That's what the "invalid token '(' in class declaration" error means. The code must be placed inside Awake(), Update(), or any other member function you define, depending on when/how you want to execute that code.
