Help  Cloth is not becoming idle after touching the ground
InformaciĆ³n
Hello Obi,
There is an issue (May be with my setup!! Not sure) where the cloth is not sleeping after touching the ground collider. The cloth is keep on moving around.
Also I would required touch and drag feature for the cloth. Please help me with some guidance for the same.
Regards,
Sujil V S
Without some description of your setup, it's pretty much impossible for me to know what's going on.
- What collision materials are you using for your cloth/ground? Do they have non-zero friction?
- What's your solver's sleep threshold setting?
For touch and drag, you have the ObiParticleDragger component available. Just add it to your cloth object and you will be able to select and drag cloth particles.
