Help  Can I get a water bulge effect on Rope
Hi I'm using Obi Rope for a hose, how can i get a water bulge effects for the rope, like in this video: https://www.youtube.com/watch?v=3T8cKTQrMxk
(15-10-2020, 01:18 PM)harut Wrote: Hi I'm using Obi Rope for a hose, how can i get a water bulge effects for the rope, like in this video: https://www.youtube.com/watch?v=3T8cKTQrMxk
Simply change particle radius at runtime. See:
Changing both color and radius is how this was made using ObiRope:
[Image: intestines.gif]
I've managed to create the bulges, but I can't change the particle color like in your Gif
I'm setting the color from here
_rope.solver.colors[solverIndex] = color;
but it dose not have any effect on rope color.
What material do you use, I'm using RedRope + ObiRopeExtrudedRenderer.
(15-10-2020, 09:36 PM)harut Wrote: I've managed to create the bulges, but I can't change the particle color like in your Gif
You must use a shader that uses vertex colors when rendering, of course. Unity's Standard shader does not. You can find lots of per-vertex colored shaders online, and there's also one included at Obi/Resources/ObiMaterials/StandardVertexColors.shader which mimics the Standard shader.
