Tearing rope on Collision
I am trying to tear the rope using OnCollision callback. The rope does get cut, but it also throws exception error when tearing.
void Solver_OnCollision(object sender, ObiSolver.ObiCollisionEventArgs e)
        for (int i = 0; i < e.contacts.Count; ++i)
            if (e.contacts.Data[i].distance < 0.01f)
                //ObiColliderBase collider = ObiColliderWorld.GetInstance().colliderHandles[e.contacts[i].other].owner;
                Component collider;
                if (ObiCollider.idToCollider.TryGetValue(e.contacts.Data[i].other, out collider))
                    if (collider == scissorCollider)
                        ObiSolver.ParticleInActor pa = solver.particleToActor[e.contacts.Data[i].particle];
                        if (pa != null)
                            ropeObject = pa.actor.GetComponent<ObiRope>();
                            ropeElements = ropeObject.elements;
                        //print(e.contacts.Data[i].particle);
                        for (int j = 0; j < ropeElements.Count; j++)
                            if( ropeElements[j].particle1 == e.contacts.Data[i].particle )
                                //print("Contact Particle: "+e.contacts.Data[i].particle);
                                //print("Element Particle: "+ropeObject.elements[j].particle1);
                                int particleToTear = ropeObject.elements[j].particle1;
                                ropeObject.Tear(ropeElements[particleToTear]);
                                ropeObject.RebuildConstraintsFromElements();
It throws index OutOfRange exception.
ArgumentOutOfRangeException: Index was out of range. Must be non-negative and less than the size of the collection.
Parameter name: index
System.ThrowHelper.ThrowArgumentOutOfRangeException (System.ExceptionArgument argument, System.ExceptionResource resource) (at <599589bf4ce248909b8a14cbe4a2034e>:0)
System.ThrowHelper.ThrowArgumentOutOfRangeException () (at <599589bf4ce248909b8a14cbe4a2034e>:0)
System.Collections.Generic.List`1[T].get_Item (System.Int32 index) (at <599589bf4ce248909b8a14cbe4a2034e>:0)
ScissorCut.Solver_OnCollision (System.Object sender, Obi.ObiSolver+ObiCollisionEventArgs e) (at Assets/Scripts/Cut Logic/ScissorCut.cs:67)
Obi.ObiSolver.EndStep () (at Assets/_IMPORTED/Obi/Scripts/Common/Solver/ObiSolver.cs:1302)
Obi.ObiUpdater.EndStep () (at Assets/_IMPORTED/Obi/Scripts/Common/Updaters/ObiUpdater.cs:104)
Obi.ObiFixedUpdater.FixedUpdate () (at Assets/_IMPORTED/Obi/Scripts/Common/Updaters/ObiFixedUpdater.cs:69)
I can't figure out, please help.
Using a particle index to look into an elements array makes no sense whatsoever. There's usually more particles than elements in a rope, hence the out of range exception. Instead of:
do
ropeObject.Tear(ropeElements[j]);
(13-10-2020, 11:43 AM)josemendez Wrote: Using a particle index to look into an elements array makes no sense whatsoever. There's usually more particles than elements in a rope, hence the out of range exception. Instead of:
do
Silly me! Thank you very much. That worked.
No worries! Sonrisa
