Help  No particles collision after resize
After I change rope length through code:
ropeCursor.ChangeLength(rope.restLength + 10);
newly added particles not colliding with each other, but old ones does.
(05-08-2020, 06:28 PM)vizgl Wrote: After I change rope length through code:
This was fixed in Obi 5.4, though it's not yet on the store. Write to support(at)virtualmethodstudio.com and I'll send it to you.
Alternatively, you can just add this line:
rope.RecalculateRestPositions();
to ObiRopeCursor.cs at the end of the ChangeLength() method. It should look like this:
rope.RebuildConstraintsFromElements();
rope.RecalculateRestLength();
Thanks, that work.
Also I found another bug in the ObiRopeBlueprint. First particle has different mass from another ones.
// In case the path is open, add a first particle. In closed paths, the last particle is also the first one.
if (!path.Closed)
particlePositions.Add(path.points.GetPositionAtMu(path.Closed,0));
particleThicknesses.Add(path.thicknesses.GetAtMu(path.Closed,0));
particleInvMasses.Add(ObiUtils.MassToInvMass(path.thicknesses.GetAtMu(path.Closed,0)));
particlePhases.Add(path.phases.GetAtMu(path.Closed,0));
particleColors.Add(path.colors.GetAtMu(path.Closed,0));
Should be:
particleInvMasses.Add(ObiUtils.MassToInvMass(path.masses.GetAtMu(path.Closed,0)));
Another bug:
After I change rope size, newly added particles has different BendCompliance behaviour
