Help  ObiRopeCursor documentation is out of date
I'm trying to use ObiRopeCursor to grow a rope for a Harpoon launcher (also running into other issues as per http://obi.virtualmethodstudio.com/forum...-2325.html). The documentation for the ropecursor (http://obi.virtualmethodstudio.com/tutor...ursor.html) mentions a Normalized Coord property. However this property no longer seems to exist. Instead, the cursor contains two properties: "sourceMu" and "cursorMu". http://obi.virtualmethodstudio.com/docs/...ursor.html
Is there updated documentation I'm missing somewhere? What is the appropriate way to set the position of new particles with ObiRopeCursor? What do "sourceMu" and "cursorMu" do?
(20-06-2020, 07:58 PM)protomenace Wrote: I'm trying to use ObiRopeCursor to grow a rope for a Harpoon launcher (also running into other issues as per http://obi.virtualmethodstudio.com/forum...-2325.html). The documentation for the ropecursor (http://obi.virtualmethodstudio.com/tutor...ursor.html) mentions a Normalized Coord property. However this property no longer seems to exist. Instead, the cursor contains two properties: "sourceMu" and "cursorMu". http://obi.virtualmethodstudio.com/docs/...ursor.html
Thanks for pointing this out! I've updated the documentation.
For convenience:
- The cursor mu is the normalized position of the cursor along the rope. This is where new particles will be inserted or removed.
- The source mu is the normalized position from which particles will be copied from, when inserting them at the cursor mu. This is useful if your rope has non-uniform thickness, color, or any other property.
(22-06-2020, 08:34 AM)josemendez Wrote: Thanks for pointing this out! I've updated the documentation.
For convenience:
Excellent, thank you!
