Add cloth and runtime
I'm trying to add ObiSkinnedCloth and reference skinnedClothBlueprint
var gameObj = meshObject.AddComponent<ObiSkinnedCloth>();
gameObj.skinnedClothBlueprint = ScriptableObject.Instantiate(SourceBlueprint.instance.sourceTop);
meshObject.AddComponent<ObiSkinnedClothRenderer>();
But I'm getting
I believe the problem is:
(17-06-2020, 03:54 PM)renderlux Wrote: I'm trying to add ObiSkinnedCloth and reference skinnedClothBlueprint
But I'm getting
Well, this can only mean SourceBlueprint, SourceBlueprint.instance or SourceBlueprint.instance.sourceTop are null. I can't possibly know which one. Try debugging your code by placing a breakpoint at that line, and check what's raising the null ref exception.
Hi
This looks like it works (no errors)
myMesh.AddComponent<ObiSkinnedCloth>();
ObiSkinnedCloth cloth = myMesh.GetComponent<ObiSkinnedCloth>();
cloth.skinnedClothBlueprint = ScriptableObject.Instantiate(sourceTop);
and I create Solver in Start()
GameObject solverObject = new GameObject("solver", typeof(ObiSolver), typeof(ObiFixedUpdater));
        ObiSolver solver = solverObject.GetComponent<ObiSolver>();
        ObiFixedUpdater updater = solverObject.GetComponent<ObiFixedUpdater>();
        updater.solvers.Add(solver);
But the physics don't work  Triste
(18-06-2020, 10:12 AM)renderlux Wrote: Hi
Is the cloth inside (the hierarchy of) a solver? It won't simulate otherwise.
Does it have a ObiSkinnedClothRenderer component? the cloth mesh won't be updated according to the simulation if it doesn't.
(18-06-2020, 10:14 AM)josemendez Wrote: Is the cloth inside (the hierarchy of) a solver? It won't simulate otherwise.
Hi
I'm adding the component :
Do I need to do anything else?
Like link ObiSkinnedCloth with ObiSkinnedClothRenderer ?
(18-06-2020, 02:34 PM)renderlux Wrote: Hi
Your cloth needs to be a child of the solver object.
Can you share you entire cloth instantiation code? this way I can tell what's missing more easily.
