How to set the particle size in the rope
May I ask where I can set the particle size in the rope. I am doing some procedural ropes and i found if I set the size and thickness very small, It will become two big particle on the head and the tail .
(03-06-2020, 08:20 PM)wenzy Wrote: May I ask where I can set the particle size in the rope. I am doing some procedural ropes and i found if I set the size and thickness very small, It will become two big particle on the head and the tail .
The blueprint resolution controls the amount of particles per length unit: See:
http://obi.virtualmethodstudio.com/tutor...setup.html
(04-06-2020, 08:04 AM)josemendez Wrote: The blueprint resolution controls the amount of particles per length unit: See:
Thanks. It's working now . I put that property setting in a wrong way
