Flag with Tear
Hi
I am trying to make a flag with tearable cloth however there seem to be some problems
The flag has particle group: static but the tearable has :top
if i rotate the tearable cloth obviously it falls part
Is it possible to make the Flag in the sample tearable?
Thanks!
(07-05-2020, 03:37 PM)ObiArgi Wrote: Hi
Thanks!
You can define your own particle groups in the blueprint editor.
Note that there's three separate blueprint and actor cloth types: regular, tearable, and skinned. You can't tear a regular cloth like the sample flag, it needs to be a tearable cloth using a tearable blueprint.
See:
http://obi.virtualmethodstudio.com/tutor...setup.html
Btw: you can simply rotate the flag, and just make it more resistant to tearing (increase its tear resistance in the inspector).
(07-05-2020, 04:57 PM)josemendez Wrote: You can define your own particle groups in the blueprint editor.
See:
i will try your suggestions
thanks!
