ship rope
How can I set the rope to hold the ship? When the ship moves, the rope is stretched and does not hold the ship. I also want to use it in towing operations.
In addition how can I set the rope length to make a longer or shorter rope ? I looked at the example scenes but I couldn't figure it out.
Thank you
[Image: PMguER.jpg]
(02-05-2020, 04:49 PM)3dship Wrote: Hi,
Thank you
[Image: PMguER.jpg]
To have two-way coupling with a rigidbody, you need to use dynamic attachments:
To set the rope initial length/rest shape, edit its path by clicking in the "Edit path" button in the inspector:
http://obi.virtualmethodstudio.com/tutor...setup.html
Thank you
I tried a lot of settings but I couldn't understand where am i doing wrong, the rope always stretches and doesn't hold the ship.
(26-05-2020, 07:40 PM)3dship Wrote: Thank you
Both attachments are clearly set to static. You need to switch the one that attaches the rope to the boat to dynamic.
