Increase stiffness (deformation resistance)?
I need to customise the behaviour of a softbody to make it more rigid and increase the damping, to make it behave less like a jelly and more like a balloon.
However the Deformation Resistance slider under Shape Matching Constraints only goes up to 1, which is not stiff enough, and I can't find anything related to damping.
Lowering the mass of the particles in the blueprint helps a little, but this seems like a bit of a hack, and setting the mass too low causes strange behaviour.
Does anyone have any suggestions? Thanks in advance.
(22-04-2020, 05:26 PM)GeorgeAmuzo Wrote: I need to customise the behaviour of a softbody to make it more rigid and increase the damping, to make it behave less like a jelly and more like a balloon.
Just increase the amount of iterations for shape matching constraints (found in ObiSolver), and/or, the amount of substeps in the ObiFixedUpdater. To see the role iterations/substeps have in the simulation, this is a good read: http://obi.virtualmethodstudio.com/tutor...gence.html
Iterative solvers in general (not just Obi) will try to reach the desired stiffness, within the simulation budget. Undersolved constraints manifest as overly "stretchy".
