Help  Question About Making Grappling Hook
Hi, my intention is making grappling hook effect. But not like in the examples. My rope is already initialized on scene. What I want to do when I press the mouse button it scales up to object's position, then pinned to the object and stay on this length.
I tried it like this;
private IEnumerator Attach_Coroutine()
       _rope.RemoveFromSolver(null);
       Quaternion lookRot =
           Quaternion.LookRotation(_rope.transform.position - GameManager.Instance.Ball.transform.position, -Vector3.forward);
       lookRot.x = 0.0f;
       lookRot.y = 0.0f;
       _rope.transform.rotation = lookRot;
       float distanceToBallFromHandle = Vector3.Distance(GameManager.Instance.Ball.transform.position, this.transform.position);
       float distanceToBallFromRopeEnd = distanceToBallFromHandle - _rope.CalculateLength();
       float attachSpeed = GameManager.Instance.handleAttachSpeed;
       _rope.AddToSolver(null);
       while (_rope.CalculateLength() <= distanceToBallFromHandle)
           _ropeCursor.ChangeLength(_rope.RestLength + attachSpeed * Time.deltaTime);
           yield return null;
       _ropePinConstraints.RemoveFromSolver(null);
       ObiPinConstraintBatch pinConstraintsBatch = _rope.PinConstraints.GetFirstBatch();
       pinConstraintsBatch.AddConstraint(_rope.UsedParticles-1, GameManager.Instance.Ball.GetComponent<ObiColliderBase>(), Vector3.zero,
           Quaternion.identity, 0);
       _ropePinConstraints.AddToSolver(null);
       _isAttached = true;
But the attachment point is not the last particle of the rope.
I attached a photo that demonstrate what I want.
Thanks in advance.
You can't "rotate" a rope whilst being simulated, it makes no sense at all. Deformable objects in general (not just ropes) cannot be transformed using a single matrix, as rotations are rigid transforms by definition: https://en.wikipedia.org/wiki/Rigid_transformation
Even if you could rotate the entire rope, gravity would immediately make it point downwards again after rotating it... this approach is just not a good idea.
I'd use external forces to coerce the rope particles (or at least the last particle) into moving towards the player. The solver has a externalForces array that you can write per-particle forces into, same as you would set velocities or positions.
