Bug / Crash  Crash on build / editor sometimes
I have simple rope for a crane control. It works most of the time on editor (not crashing). But it crashes 100% on windows build. I don't know what could be the issue. Here are the settings.
[attachment=519]
[attachment=520]
[attachment=521]
[attachment=522]
Update: I just found out if I switch to Mono from IL2CPP it will work fine on the build. Does the plugin only works on Mono?
(03-12-2019, 11:57 AM)LORDeveloper Wrote: Hello,
Unable to reproduce here, works fine with IL2CPP and Mono. As far as I know we are not doing anything that would make it dependant a specific Unity compiler backend (most of our code comes precompiled in a native library, so it's not even compiled by Unity at build time).
Could you share your crash log/stacktrace? Also what Unity version are you using?
(03-12-2019, 02:42 PM)osemendez Wrote: Hi there,
I am using Unity 2019.2. There is no crash log/sacktrace as it gives me a popup saying the program is exiting/crashing. Then nothing shows up afterwards.
(03-12-2019, 02:42 PM)josemendez Wrote: Hi there,
I found out what happened. I need to put Architecture to x86_64.
