Help  (Obi 5.0) How to preview Obi simulation while in edit mode.
Hi.
I immediately updated to Obi 5.0 using Unity 2019.
The blueprint system seems to be good.
However, I could't found how to simulate in edit mode like particle editor in 4.X.
The simulation function was removed from 5.0?
(23-11-2019, 09:19 AM)asimofu_ok Wrote: Hi.
Yes it was removed from 5.0, as previewing it with the current architecture would require the blueprint data to be serialized in each actor, which is something we wanted to avoid at all costs. We had to choose, so in-editor simulation had to go. Triste
(23-11-2019, 11:46 AM)josemendez Wrote: Hi,
I see.
I hope to add some alternative function.
(23-11-2019, 03:46 PM)asimofu_ok Wrote: I see.
In the near future I want to find an alternative solution. Will keep you updated in the Announcements subforum.
