Hi guys,
We're having an issue getting Obi rope to work correctly when the Solver is assigned at runtime, is there a way to force re-initialisation when we attached the solver?
We already use a Solver for fluid in another scene, and when we come into the scene with the ropes we wanted to use the same solver (as I assume having 2 solvers is more expensive than 1?)
so my questions:
1) Is there a way to re-init?
2) Is having 2 solvers much more expensive than 1?
3) Which behavioursĀ are needed for rope solver (volume, shape matching etc) for the most lightweight solver, is there a scene with an example?
Thanks very much for your help guys.
Tim
InĀ an addition to this, after hitting initialise on the rope prefab, we can no longer add pin constraints, is this something you're aware of?
so my questions:
Tim
