Im new to Obi and i have a problem with the collisions.
I have a flask which is generating a liquid(Obi Emiiter) and a floor (Obi Collider) that interacts with that liquid.
I made different floors each one with the PhLandController script that i only want to call when the liquid collides with the floor
I also have an (Obi Solver) which have the following script.
The problems is that after i remove the liquid from colliding to the floor the method increasePHLevel() is call infinitly.
The only way to stop it is that the liquid begins a new collision with a different floor but the problem is now pass to the new floor method is call infinitly.
Any suggestion how i could fix this ?
Thanks
using UnityEngine;
using System.Collections;
using Obi;
public class FluidPhCollisionHandler : MonoBehaviour {
ObiSolver solver;
PhLandController phController;
void Awake(){
solver = GetComponent<Obi.ObiSolver>();
void OnEnable () {
void OnDisable(){
void Solver_OnCollision (object sender, Obi.ObiSolver.ObiCollisionEventArgs e)
Oni.Contact contact = e.contacts[0];
Component collider;
if (ObiCollider.idToCollider.TryGetValue(contact.other,out collider)){
phController = collider.GetComponent<PhLandController>();
phController.increasePHLevel();
Thanks
