Bug / Crash  Ubuntu Editor errors
I've used Obi Rope successfully on a windows machine.
When loading the scene in a Linux editor, I get the following errors:
DllNotFoundException: libOni
Obi.ObiBoxShapeTracker..ctor (UnityEngine.BoxCollider collider) (at Assets/ZZZ_External/Obi/Scripts/Collisions/ColliderTrackers/Trackers3D/ObiBoxShapeTracker.cs:14)
Obi.ObiCollider.CreateTracker () (at Assets/ZZZ_External/Obi/Scripts/Collisions/ObiCollider.cs:65)
Obi.ObiColliderBase.AddCollider () (at Assets/ZZZ_External/Obi/Scripts/Collisions/ObiColliderBase.cs:129)
Obi.ObiCollider.Awake () (at Assets/ZZZ_External/Obi/Scripts/Collisions/ObiCollider.cs:111)
UnityEngine.GUIUtility:ProcessEvent(Int32, IntPtr)
Obi.ObiColliderBase.OnDisable () (at Assets/ZZZ_External/Obi/Scripts/Collisions/ObiColliderBase.cs:235)
Obi.ObiSolver.Initialize () (at Assets/ZZZ_External/Obi/Scripts/Solver/ObiSolver.cs:311)
UnityEngine.Debug:LogException(Exception)
Obi.ObiSolver:Initialize() (at Assets/ZZZ_External/Obi/Scripts/Solver/ObiSolver.cs:438)
Obi.ObiSolver:OnEnable() (at Assets/ZZZ_External/Obi/Scripts/Solver/ObiSolver.cs:277)
Obi.ObiConstraintBatch.Enable () (at Assets/ZZZ_External/Obi/Scripts/Constraints/ConstraintBatches/ObiConstraintBatch.cs:132)
Obi.ObiBatchedConstraints.Enable () (at Assets/ZZZ_External/Obi/Scripts/Constraints/ObiBatchedConstraints.cs:71)
Obi.ObiBatchedConstraints.OnEnable () (at Assets/ZZZ_External/Obi/Scripts/Constraints/ObiBatchedConstraints.cs:127)
Please advise.
Thanks in advance
(08-07-2019, 07:33 AM)Nir Hermoni Wrote: Hi,
UnityEngine.GUIUtilityLenguarocessEvent(Int32, IntPtr)
Please advise.
Thanks in advance
Simply restart Unity. See the FAQ:
(08-07-2019, 08:04 AM)josemendez Wrote: Simply restart Unity. See the FAQ:
Thanks for the reply. It didn't work.
The errors show up when I load the scene with a rope. I can clear them, but they reappear in play mode.
Seems something is bork with newer versions of Unity. 2018.3.5 I had to manually copy libOni.so into Mono/lib. with 2018.4.8 it still can't find it.
Previous thread: http://obi.virtualmethodstudio.com/forum...d-964.html
Unity is still looking in $blah/Mono/lib but just won't load the damn thing Triste
Refreshing native plugins compatible for Editor in 3.72 ms, found 2 plugins.
Fallback handler could not load library /home/phosphers/Unity/Hub/Editor/2018.4.8f1/Editor/Data/Mono/lib/libOni
Fallback handler could not load library /home/phosphers/Unity/Hub/Editor/2018.4.8f1/Editor/Data/Mono/lib/libOni.so
Fallback handler could not load library /home/phosphers/Unity/Hub/Editor/2018.4.8f1/Editor/Data/Mono/lib/./libOni
Fallback handler could not load library /home/phosphers/Unity/Hub/Editor/2018.4.8f1/Editor/Data/Mono/lib/./libOni.so
And libOni.so is in that directory
