29-06-2019, 03:53 AM
My project is using Render Pipeline and The particles don't appears! and all Obi Shaders are obsolete from this! How to fix it??
Bug / Crash Don't works in HDRP projects Unity 2019
01-07-2019, 07:03 AM
(This post was last modified: 01-07-2019, 07:04 AM by josemendez.)
(29-06-2019, 03:53 AM)conceptfac Wrote: My project is using Render Pipeline and The particles don't appears! and all Obi Shaders are obsolete from this! How to fix it??The built-in renderers have only been tested with Unity's built-in pipeline. See the FAQ: http://obi.virtualmethodstudio.com/tutorials/ Quote: Quote:Cloth, Rope and Softbodies support SRP out of the box, since they do not perform any custom rendering. Obi Fluid does include a custom rendering pipeline based on screen-space ellipsoid splatting, that has yet to be tested for compatibility with SRP. Upcoming versions will provide a FluidRenderer that works with SRP. For the time being you can write your own, as the fluid rendering pipeline is designed to be extensible. See: http://obi.virtualmethodstudio.com/tutor...ering.html |
« Next Oldest | Next Newest »
