Threads: 4
24-06-2019, 07:17 AM
(This post was last modified: 24-06-2019, 07:46 AM by jirawatball.)
(24-06-2019, 07:17 AM)jirawatball Wrote: this is my config.
https://www.youtube.com/watch?v=LX28L1sfU8Y
it so soft i need it stronger.
and this thing i want.
https://www.youtube.com/watch?v=ehUyS_2_ke4
You should not use a particle based solver like Obi for this. It's not its intended use case.
Instead, use a cable simulator like Filo:
https://assetstore.unity.com/packages/to...tor-133620
Threads: 4
(24-06-2019, 08:44 AM)josemendez Wrote: Hi,
When I use Filo It can't rotation object still forward rotate.
(25-06-2019, 04:36 AM)jirawatball Wrote: When I use Filo It can't rotation object still forward rotate.
Sorry, I don't understand your question. Can you reformulate it, and/or provide more details on what you're trying to do?
Threads: 4
(25-06-2019, 07:20 AM)josemendez Wrote: Hi,
When I used Filo on a crane, the rotation of the hook won't follow the rotation of the car. And I've made a lot of progress in this project with Obirope, so I'd rather want to know a suggestion on how to setup the rope and make it less bouncy.
https://youtu.be/HnI8GriCBq8
25-06-2019, 12:23 PM
(This post was last modified: 25-06-2019, 12:29 PM by josemendez.)
(25-06-2019, 10:38 AM)jirawatball Wrote: When I used Filo on a crane, the rotation of the hook won't follow the rotation of the car. And I've made a lot of progress in this project with Obirope, so I'd rather want to know a suggestion on how to setup the rope and make it less bouncy.
Filo cables do not support torsion, but neither do ropes in ObiRope. If you need torsion forces you have to use ObiRods instead. Here's a comparison table:
http://obi.virtualmethodstudio.com/tutor...ropes.html
To make the rope less bouncy, increase the amount of distance constraint iterations in the solver, and/or reduce Unity's physics timestep. Both come at a performance cost though. Reducing the rope resolution will result in less constraints, improving convergence (higher reachable stiffness). See:
But again, my advice is to use Filo for this. It is specifically designed for this use case. Using a particle based solver for industrial crane simulation is just doomed to failure.
Threads: 4
(25-06-2019, 12:23 PM)josemendez Wrote: Hi,
https://youtu.be/7c73ecC1P2c
now I Config rigibody object
https://www.img.in.th/image/Em5G9L
https://www.img.in.th/image/Em52m3
it's look better but I have a about distance issues, do you have any suggestions? it stretched.
27-06-2019, 08:57 AM
(This post was last modified: 27-06-2019, 08:58 AM by josemendez.)
(27-06-2019, 05:08 AM)jirawatball Wrote: https://youtu.be/7c73ecC1P2c
it's look better but I have a about distance issues, do you have any suggestions? it stretched. Do not use parallel mode for this, it converges very slowly compared to sequential. Use sequential mode for all constraints, as you need the system to converge as fast as it possibly can. Quoting the manual:
Quote:Parallel mode converges slowly and isn't guaranteed to conserve momentum (things can sometimes gain energy). So use sequential mode when you can, and parallel mode when you must.
Also, try using 2 subsets instead of 1.
