Sticking two Obi Ropes together
Is it possible to stick two Obi Ropes together so they stick at certain points?
[Image: b3TR4JK]
https://imgur.com/b3TR4JK
The picture above shows what I mean. I want these two ropes to stick together at these 3 places (marked green). I was thinking of doing them with pin constraint but I have no idea how to set the object to follow the curve when it moves?
Is such a thing possible with Obi Rope?
Thank you!
(16-05-2019, 05:24 PM)klemen.vip Wrote: Hello,
[Image: b3TR4JK]
Thank you!
Use stitch constraints, they are designed for this use case specifically. Add a ObiStitcher component to an object, then set the two ropes as the actors to be stitched and add stitches between their particles.
