Obi Support for 2018.3 and SRP?
Before buying the full suite, we wanted to check and see which assets are compatible with 2018.3 and SRP projects:
Obi Fluid - looks like 2018.3 is supported but NOT SRP?
Obi Rope - Same as Fluid
Obi Cloth - Works with 2018.3 and SRP but requires material swap from default?
Obi Softbody - Works with 2018.3 but NOT SRP?
Do we have these correct? Really hoping to implement Rope and Fluid into our HDRP projects. Thanks!
(04-05-2019, 10:57 PM)Josterday Wrote: Before buying the full suite, we wanted to check and see which assets are compatible with 2018.3 and SRP projects:
Obi Fluid - Works with 2018.3. None of the default SRPs are supported by the included shaders (though you can write your own or modify the existing ones). Only the default rendering pipeline works out of the box with the included shaders.
Obi Rope - Works with 2018.3. Any shader/material can be used with ropes, it does nothing custom rendering-wise, so it works with any SRP.
Obi Cloth - Works with 2018.3. Any shader/material can be used with cloth, it does nothing custom rendering-wise, so it works with any SRP.
Obi Cloth - Works with 2018.3. Any shader/material can be used with soft bodies, it does nothing custom rendering-wise, so it works with any SRP.
So all Obi assets work with SRPs as well as the default rendering pipeline. Only Obi Fluid does a bit of custom rendering, and so needs to be tweaked depending on which rendering pipeline you use.
Thanks and Great to hear. We'll take a look at Fluid. If it's just a matter of pointing it to a different shader with minimal code, then we're all set.
Any bundles available for the suite? We grabbed Ara, Filo, and Simple SSAO as well. Looking to add Rope, Softbody, and Fluid now with the SRP support.
