02-05-2019, 02:46 PM
Is there any way to swap between 2D and 3D mode on a obi solver (fluids) in runtime? I am trying to access the variable/parameter trough scripting, but I can not find a "Mode" on the Obisolver. Either I am looking in the wrong place - or the answer is "no you can not"?
And since someone always asks "Why would you want to do that" let me clarify that I understand I can not do both 2d and 3d at the *same* time.
It just would like using the same one solver and swap between 3d and 2d mode and keep all other settings - instead of setting up another one and point emitters back and forth and make sure all things match up. It is a visual effect thing that happens in between some other things in a visual art thing.
