When use softbody. my skinned mesh messed up
if no softbody used ,then everything is fine.
if attach the softbody,then mesh messed up.
without softbody
[attachment=300]
with softbody
[attachment=301]
the shoulder and chest are messed up
(23-03-2019, 04:04 PM)songsongsong Wrote: if no softbody used ,then everything is fine.
without softbody
with softbody
Make sure the softbody's "skinning max distance" is small enough not to grab vertices too far away from the softbody particles. See:
http://obi.virtualmethodstudio.com/tutor...setup.html
(25-03-2019, 12:14 PM)josemendez Wrote: Make sure the softbody's "skinning max distance" is small enough not to grab vertices too far away from the softbody particles. See:
thank you. that fixed it.
