  • 2 Vote(s) - 3.5 Average
"Edit Particles" NullReferenceException
I am getting the following error when clicking "Edit Particles"
Obi.ObiPinConstraints.OnDrawGizmosSelected () (at Assets/Obi/Scripts/Constraints/ObiPinConstraints.cs:52)
UnityEngine.GUIUtilityLenguarocessEvent(Int32, IntPtr)
Obi.ObiParticleActorEditor.DrawParticles () (at Assets/Obi/Editor/ObiParticleActorEditor.cs:332)
Obi.ObiParticleActorEditor.DrawActorInfo () (at Assets/Obi/Editor/ObiParticleActorEditor.cs:598)
Obi.ObiParticleActorEditor.OnSceneGUI () (at Assets/Obi/Editor/ObiParticleActorEditor.cs:262)
System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MonoMethod.cs:222)
Rethrow as TargetInvocationException: Exception has been thrown by the target of an invocation.
System.Reflection.MonoMethod.Invoke (System.Object obj, BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MonoMethod.cs:232)
System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) (at /Users/builduser/buildslave/mono/build/mcs/class/corlib/System.Reflection/MethodBase.cs:115)
UnityEditor.SceneView.CallOnSceneGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:2408)
UnityEditor.SceneView.HandleSelectionAndOnSceneGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:1737)
UnityEditor.SceneView.OnGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:1569)
UnityEditor.HostView.Invoke (System.String methodName, System.Object obj) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:272)
UnityEditor.HostView.Invoke (System.String methodName) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:265)
UnityEditor.HostView.InvokeOnGUI (Rect onGUIPosition) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:232)
(05-09-2017, 12:11 PM)RoryMakarov Wrote: I am getting the following error when clicking "Edit Particles"
what Unity and Obi versions are you using?
(05-09-2017, 03:54 PM)josemendez Wrote: Hi!
2017.1.0p4 and the latest asset
(05-09-2017, 04:19 PM)RoryMakarov Wrote: 2017.1.0p4 and the latest asset
Could reproduce this. Thanks for reporting it! Wwll include the fix in the next update, for now replace the OnDrawGizmosSelected function in ObiPinConstraints.cs with this:
public void OnDrawGizmosSelected(){
        if (!visualize) return;
        Gizmos.color = Color.cyan;
        foreach (ObiPinConstraintBatch batch in batches){
            foreach(int i in batch.ActiveConstraints){
                if (batch.pinBodies[i] != null){
                    Vector3 pinPosition = batch.pinBodies[i].transform.TransformPoint(batch.pinOffsets[i]);
                    Gizmos.DrawLine(actor.GetParticlePosition(batch.pinIndices[i]),
                                    pinPosition);
A NullReferenceException exception is thrown when you try to access a member on a type whose value is null. A NullReferenceException exception typically reflects as developer error. To fully understand why a NullReferenceException is thrown, it is important to know the difference between value types and reference types.
So, if you're dealing with value types, NullReferenceExceptions can not occur. Though you need to keep alert when dealing with reference types!
Only reference types, as the name is suggesting, can hold references or point literally to nothing (or 'null'). Whereas value types always contain a value.
Reference types (these ones must be checked):
  • dynamic
  • object
  • string
Value types (you can simply ignore these ones):
  • Numeric types
  • Integral types
  • Floating-point types
  • decimal
  • bool
  • User defined structs
