Help help technique
hi, i am currently new at obj rope, i want to make something draw like this video, can i make this by rope? tks all.
https://www.youtube.com/watch?v=5oMuzbDGNlY&t=318s
(11-05-2020, 10:24 AM)duychuong Wrote: hi, i am currently new at obj rope, i want to make something draw like this video, can i make this by rope? tks all.
Why do you need rope simulation for this? There's absolutely no physics going on in the video. A simple trail/line renderer would be more than enough, not to mention much more performant and easier to use.
(11-05-2020, 10:26 AM)josemendez Wrote: Hi there!
because it wanna like this https://www.youtube.com/watch?v=VHsDwhESwjY&t=50s. i want the cream have gravity and can move. I am new in 3D and physics 3D too.
(11-05-2020, 11:02 AM)duychuong Wrote: because it wanna like this https://www.youtube.com/watch?v=VHsDwhESwjY&t=50s. i want the cream have gravity and can move. I am new in 3D and physics 3D too.
Believe it or not, there's also very little physics involved in this second video. It's basically a list of points, trough which a circular shape is extruded to generate a tube. That's all. The only "physics" here would be gravity, which is already built-in in Unity. There are no contacts, friction, tensional or bending constraints here, and certainly no need for a particle-based / position-based dynamics engine.
If you're new to 3D and physics, I'd advise against starting with Obi. It is quite complex, and assumes certain familiarity with basic physics concepts. If you're willing to put in the time then by all means go ahead, but in this particular case it would even be counterproductive using Obi as there's much simpler and faster alternatives to do what you're describing.
(11-05-2020, 11:12 AM)josemendez Wrote: Hi,
If you're new to 3D and 3D physics, I'd advise against starting with Obi. It is quite complex, and assumes certain familiarity with basic physics concepts. In this particular case, it would even be counterproductive using it as there's much better and simpler alternatives to do what you're describing.
Thank you, it 's really useful for me
