Help Modifying Emitter
Current emitter kills particles by lifespan. I want emitter to kill by position (For example, if a particle's Y position is below -5).
I managed to kill by that, but now emitter isn't working properly after when a particle is killed. How can I fix this?
Here's my CustomEmitter:
namespace Obi
  [AddComponentMenu("Physics/Obi/Obi Emitter", 850)]
  [ExecuteInEditMode]
  public class CustomObiEmitter : ObiActor
     [SerializeField] private float[] _posYs;
     public override void LoadBlueprint(ObiSolver solver)
        _posYs = new float[particleCount];
        for (var i = 0; i < _posYs.Length; ++i)
           _posYs[i] = 1;
     protected override void SwapWithFirstInactiveParticle(int index)
        _posYs.Swap(index, activeParticleCount);
     public bool EmitParticle(float offset, float deltaTime)
        _posYs[activeParticleCount] = 1;
     public override void BeginStep(float stepTime)
        for (int i = activeParticleCount - 1; i >= 0; --i)
           _posYs[i] = m_Solver.positions[i].y;
           if (_posYs[i] <= -5)
              KillParticle(i);
(14-02-2020, 01:59 PM)ilterbilguven Wrote: Hi,
namespace Obi
  [ExecuteInEditMode]
           _posYs[i] = 1;
              KillParticle(i);
Why not simply setting the particle's life to zero when it meets the condition you want (y < -5) instead of modifying the emitter class itself? Huh
(14-02-2020, 02:59 PM)josemendez Wrote: Why not simply setting the particle's life to zero when it meets the condition you want (y < -5) instead of modifying the emitter class itself?   Huh
Well, that's simple too. I want to keep that as a time-based emitter, mine is position-based.
Anyway, your solution shows same result. To illustrate: I have 2000+ particles. At the beginning (e.g after 50th particle), if a particle hits the condition, emitter stops working properly.
