Help Collide between two ropes
I'm using Obi Rope 5.1 and i need detect collisions (or lack of collisions)  between two ropes. I put two ropes with different tags under common Obi Solver and and I received messages from ObiSolver.OnCollision.
   private void M_ObiSolver_OnCollision(ObiSolver solver, ObiSolver.ObiCollisionEventArgs contact)
       foreach (Oni.Contact contactItem in contact.contacts)
           ObiSolver.ParticleInActor pa = solver.particleToActor[contactItem.particle];
           Component collider;
           if (ObiCollider.idToCollider.TryGetValue(pa.actor.GetInstanceID(), out collider))
               //avoid floor collision
               if (collider.CompareTag("floorTag"))
                   return;
               if (contactItem.distance < 0.01)
                   if (!pa.actor.CompareTag(collider.tag))
                       print($"rope({pa.actor.name}) touched another rope({collider.name})");
                   else if (pa.actor.CompareTag(collider.tag))
                       print($"rope({pa.actor.name}) touched itself({collider.name})");
But i did not get collider of another rope.
How I can get collision between two ropes?
(11-02-2020, 01:44 PM)tda777 Wrote: I'm using Obi Rope 5.1 and i need detect collisions (or lack of collisions)  between two ropes. I put two ropes with different tags under common Obi Solver and and I received messages from ObiSolver.OnCollision.
           Component collider;
                   return;
Ropes do not use colliders. They use particles. That's the whole point of a particle-based physics engine.  Guiño
To get the particle-particle collision events that happened during a frame, subscribe to solver.OnParticleCollision. The contact will contain the indices of the 2 particles involved, instead of a particle index and a collider index.
