Help  Index was outside the bounds of the array
I'm trying to add simulation to a character but I'm having an issue when I have two actors for one solver. (See Attachment)
Hierarchy(Only the important part):
ClothSolver (ObiLateFixedUpdater + ObiSolver)
----> Character (Animator on Fixed Update)
--------->Jersey (ObiSkinnedCloth + ObiSkinnedClothRenderer)
--------->Pants  (ObiSkinnedCloth + ObiSkinnedClothRenderer)
So if I only have the ObiSkinnedCloth on the Jersey or the Pants it works but when its applied on both I'm getting "Index was outside the bounds of the array".
I can have two actors for one solver right?
Cheers,
(20-01-2020, 09:51 PM)arthamas Wrote: Hi,
Cheers,
Had a similar from another user report yesterday. This seems like a bug, and yes, you're supposed to be able to use more than one actor per solver. Will take a look at it this morning and get back to you asap.
Indeed, it was a bug. Thanks you both for finding and reporting it.
Change lines 153-162 of ObiSkinnedCloth.cs with this:
int solverIndex = batch.particleIndices[i];
int actorIndex = solver.particleToActor[solverIndex].indexInActor;
batch.skinPoints[i] = skinToSolver.MultiplyPoint3x4(sortedPoints[actorIndex]);
batch.skinNormals[i] = skinToSolver.MultiplyVector(sortedNormals[actorIndex]);
// Rigidly transform particles with zero skin radius and zero compliance:
if (Mathf.Approximately(batch.skinRadiiBackstop[i * 3], 0) & Mathf.Approximately(batch.skinCompliance[i], 0))
     solver.invMasses[solverIndex] = 0;
     solver.positions[solverIndex] = batch.skinPoints[i];
That should fix it. I'm attaching the entire corrected file for convenience.
Let me know how it goes.
.cs   ObiSkinnedCloth.cs (Size: 7.36 KB / Downloads: 3)
