Softbody inflate using pressure/volume/distance constraints?
Hey, It's pretty cool you can overpressurise a "soft body" using ObiCloth for a variety of effects. Can the same be done using ObiSoftbody? How would you create a softbody object that inflates? I'm trying to create an expanding slime creature.
Thank you!
(06-01-2020, 01:40 PM)Neuroticcheeze Wrote: Hey, It's pretty cool you can overpressurise a "soft body" using ObiCloth for a variety of effects. Can the same be done using ObiSoftbody? How would you create a softbody object that inflates? I'm trying to create an expanding slime creature.
Thank you!
Nope, softbodies and balloons are quite different in both behavior and implementation. Softbodies are assumed to be "solid", balloons (inflated cloth) are thin membranes filled with air.
