Help  ObiFluid doesn't work with Cinemachine?
I'm using ObiFluid in a 2D game with a SimpleFluidRenderer on an Android platform.
It works like a miracle.
However, when I add a Virtual Camera (cinemachine package) the water particles are not rendering at all. I couldn't figure out what the problem is, but I think this is connected to the Camera Brain.
I think because if I duplicate the original camera before adding a virtual camera to the scene, and turning that copy camera (without the brain) on, the water appears.
Could you help me on this please?
(16-12-2019, 04:05 PM)Runemark Studio Wrote: Hi!
Virtual Cameras are basically "logic" cameras that are used to switch between cameras that have a camera brain, so as long as the Camera has a FluidRenderer things should work. Haven't tested with Cinemachine, so I will and get back to you asap.
Yep, you are right. Not sure what was the problem, but successfully solved it this morning.
I did the following steps:
  1. Reverted the scene to the working one (with no cinemachine)
  2. Added a camera brain to the camera
  3. Reset the camera component
At this point the fluid was working. When I added a virtual camera to the scene, the particles didn't render.
I could solve this problem by setting Clipping Planes to the original camera settings:
  • Near: 0.3
  • Far: 1000
The virtual camera changed these to 0.1 and 2000.
I'm wondering how these two settings affect the particle rendering
