Connect two ropes together?
Hello, thanks for great asset!
My question would if it's possible to connect two seperate ropes together? My use case is as follows: I have a electricity wire coated with isolation layer (just a blue rope), I need to make an effect that user can remove the isolation layer when a knife comes near the end of the wire (only in one spot on whole rope). So my idea was to have separate ropes connected (one long and two short ones). Firstly, the wire is made out of long blue rope and short blue rope, then when knife comes close, disable the short blue rope and enable the short exposed wire-colored rope. If it's possible or if there is a better solution please let me know. Thank you.
I think its possible to do, just pin the last particle of both ends to one another.
