How to lock obi rope axis?
Hey, I've set up a rope using the grappling hook template as a base, however, I need to lock the Z axis of the rope's movement. I can't see anywhere on the forums or in the inspector where I can do this. Any help would be greatly appreciated! Thanks.
(24-09-2019, 10:40 AM)Jhulse Wrote: Hey, I've set up a rope using the grappling hook template as a base, however, I need to lock the Z axis of the rope's movement. I can't see anywhere on the forums or in the inspector where I can do this. Any help would be greatly appreciated! Thanks.
Go to ObiSolver: Switch MODE from Mode 3D to Mode 2D.
In play mode it clamps it two only two directions. If it doesn't swing on the desired axis look at the rope transform in the inspector and play with its Rotation values.
