particles
I would like to have a variable to adjust the size of the particle.  In the picture, the rope is smaller than the particles.
I would like the ability to change the particle as seen below.
[Image: obirope.png]
Insure ObiRope.Thickness from Paticles is checked.
Manually you can edit each particle, and set its Radius.
.png   Capture.PNG (Size: 14.29 KB / Downloads: 2)
Or use code to alter the particle radius.
(16-09-2017, 06:56 PM)Parker Wrote: I would like to have a variable to adjust the size of the particle.  In the picture, the rope is smaller than the particles.
In addition to what tbookout said (you can specify the radius for each individual particle by using the particle editor), you can also scale your rope mesh thickness down/up independently of particle radius: "Section thickness scale" variable, under the "Rendering" section of ObiRope's inspector.
