Help  Obi tearable cloth
I asked almost same question, but I could not get sign of when it is torn. I want an example to achieve.
(30-04-2019, 03:52 PM)Richard Wrote: I asked almost same question, but I could not get sign of when it is torn. I want an example to achieve.
You already asked this same question, and a complete example was provided. See:
http://obi.virtualmethodstudio.com/forum...t=callback
This is the sample code. Simply subscribe a function to the cloth's OnConstraintTorn callback. That's all there is to it:
using System.Collections;
using UnityEngine;
using Obi;
[RequireComponent(typeof(ObiTearableCloth))]
public class ClothTornEvent : MonoBehaviour {
   ObiTearableCloth cloth;
   public GameObject thingToSpawn;
   void OnEnable () {
       cloth = GetComponent<ObiTearableCloth>();
       cloth.OnConstraintTorn += Cloth_OnConstraintTorn;
   void OnDisable(){
       cloth.OnConstraintTorn -= Cloth_OnConstraintTorn;
   void Cloth_OnConstraintTorn (object sender, ObiTearableCloth.ObiConstraintTornEventArgs e)
       if (thingToSpawn != null)
           GameObject.Instantiate(thingToSpawn,cloth.Solver.positions[cloth.particleIndices[e.particleIndex]],Quaternion.identity);
(01-05-2019, 12:34 AM)josemendez Wrote: Hi,
using UnityEngine;
using Obi;
   void OnEnable () {
   void OnDisable(){
How can I callback with that?
(01-05-2019, 01:37 AM)Richard Wrote: How can I callback with that?
This is a regular C# event. Please read on how to use them.
https://www.tutorialspoint.com/csharp/csharp_events.htm
https://www.tutorialsteacher.com/csharp/csharp-event
(01-05-2019, 09:50 AM)josemendez Wrote: This is a regular C# event. Please read on how to use them.
I used code like this
using UnityEngine;
using Obi;
   void Start()
       this.GetComponent<ClothTornEvent>().enabled = false;
   void OnEnable()
   void OnDisable()
   void Cloth_OnConstraintTorn(object sender, ObiTearableCloth.ObiConstraintTornEventArgs e)
       Debug.Log("1");
           GameObject.Instantiate(thingToSpawn, cloth.Solver.positions[cloth.particleIndices[e.particleIndex]], Quaternion.identity);
           Debug.Log("2");
However, I could not see "1" or "2" when the cloth is tore.  I need another thing? How can I get input from obi tearable cloth?
(01-05-2019, 11:42 AM)Richard Wrote: I used code like this
using UnityEngine;
using Obi;
   void Start()
   void OnEnable()
   void OnDisable()
       Debug.Log("1");
           Debug.Log("2");
Maybe not disabling your component immediately in Start() would work Guiño
(01-05-2019, 11:52 AM)josemendez Wrote: Maybe not disabling your component immediately in Start() would work Guiño
I wrote the code because of another problem, but it is okay now. Sorry.
