Help  Character collision issue
Hi I've set up obi colliders on the leg bones and have set up the character cloth using the solver at the root. However there are issues where the cloth is going through and getting stuck on the leg colliders during movement. Please take a look at this vid as its showing whats happening, thankyou-
https://youtu.be/zYMSDsEGNNI
(24-04-2019, 11:50 AM)howzer Wrote: Hi I've set up obi colliders on the leg bones and have set up the character cloth using the solver at the root. However there are issues where the cloth is going through and getting stuck on the leg colliders during movement. Please take a look at this vid as its showing whats happening, thankyou-
Make sure you're using skin constraints to keep the cloth following the animation. Relying on pure collision/particle contacts for animation is not recommended, as it generally causes tunneling (which is what you're getting here).
Thanks, I activated the skin constraint and there is some improvement but the cloth still seems to be clipping through the collider on the legs. I think the collider size and set up is fine so Im not sure whats causing this issue.
https://youtu.be/ruKaalrN4Hk
