02-10-2017, 05:52 PM
Is there any way to set a rope to not stretch at all and to extend more rope whenever it's pulled? A mode where there is never any strain or tension, and the rope is in a free-fall state, where even gravity will pull on the rope. It's also important to be able to turn this mode off without a sudden spring-back behavior in the rope.
- I've tried using a temporary Obi Handle for the end of the rope, and set the rope's length to the distance between the rope's start & end before disabling the handle; but this didn't help with the spring-back problem.
- I've also tried increasing the rope's length any time the strain (calculated using Rope.CalculateLength() / Rope.RestLength) passes 1. This however was not stable or precise, which made it unfavorable.
This is currently the one thing stopping me from being able to use Obi in my product & it would make my day if I could find a solution for this.
