(16-04-2019, 10:15 PM)josemendez Wrote: Hi,
We cannot reproduce the issue. Make sure you've clicked the "Initialize" button in the cloth component after regenerating the topology, as this is the step that actually setups the cloth using the topology.
I have remade the whole cloth setup from scratch, nothing seems to work at all. May I add that the simulation actually does play in the particle editor (after making Unity crash several times).
While testing on a completely new version of the mesh, going into the particle Editor throws this error:
Obi.ObiClothEditor.UpdateParticleEditorInformation () (at Assets/Obi/Editor/ObiClothEditor.cs:96)
Obi.ObiParticleActorEditor.OnSceneGUI () (at Assets/Obi/Editor/ObiParticleActorEditor.cs:247)
System.Reflection.MonoMethod.Invoke (System.Object obj, System.Reflection.BindingFlags invokeAttr, System.Reflection.Binder binder, System.Object[] parameters, System.Globalization.CultureInfo culture) (at <1f0c1ef1ad524c38bbc5536809c46b48>:0)
Rethrow as TargetInvocationException: Exception has been thrown by the target of an invocation.
System.Reflection.MethodBase.Invoke (System.Object obj, System.Object[] parameters) (at <1f0c1ef1ad524c38bbc5536809c46b48>:0)
UnityEditor.SceneView.CallOnSceneGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:3275)
UnityEditor.SceneView.HandleSelectionAndOnSceneGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:2522)
UnityEditor.SceneView.OnGUI () (at C:/buildslave/unity/build/Editor/Mono/SceneView/SceneView.cs:2383)
UnityEditor.HostView.Invoke (System.String methodName, System.Object obj) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:345)
UnityEditor.HostView.Invoke (System.String methodName) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:339)
UnityEditor.HostView.InvokeOnGUI (UnityEngine.Rect onGUIPosition, UnityEngine.Rect viewRect) (at C:/buildslave/unity/build/Editor/Mono/HostView.cs:315)
UnityEditor.DockArea.DrawView (UnityEngine.Rect viewRect, UnityEngine.Rect dockAreaRect, System.Boolean floatingWindow, System.Boolean isBottomTab) (at C:/buildslave/unity/build/Editor/Mono/GUI/DockArea.cs:373)
UnityEditor.DockArea.OldOnGUI () (at C:/buildslave/unity/build/Editor/Mono/GUI/DockArea.cs:340)
UnityEngine.UIElements.IMGUIContainer.DoOnGUI (UnityEngine.Event evt, UnityEngine.Matrix4x4 parentTransform, UnityEngine.Rect clippingRect, System.Boolean isComputingLayout, UnityEngine.Rect layoutSize) (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:295)
UnityEngine.UIElements.IMGUIContainer.HandleIMGUIEvent (UnityEngine.Event e, UnityEngine.Matrix4x4 worldTransform, UnityEngine.Rect clippingRect) (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:481)
UnityEngine.UIElements.IMGUIContainer.HandleIMGUIEvent () (at C:/buildslave/unity/build/Modules/UIElements/IMGUIContainer.cs:455)
UnityEngine.UIElements.UIR.ImmediateRenderer.Draw (UnityEngine.UIElements.UIR.DrawChainState dcs) (at C:/buildslave/unity/build/Modules/UIElements/Renderer/UIRenderer/UIRenderers.cs:447)
UnityEngine.UIElements.UIR.UIRenderDevice.ContinueChain (UnityEngine.UIElements.UIR.RendererBase head, UnityEngine.UIElements.UIR.DrawChainState dcs, System.Boolean outerChainsWithMeshRenderer) (at C:/buildslave/unity/build/Modules/UIElements/Renderer/UIRenderer/UIRenderDevice.cs:841)
UnityEngine.UIElements.UIR.UIRenderDevice.DrawChain (UnityEngine.UIElements.UIR.RendererBase head, UnityEngine.Rect viewport, UnityEngine.Matrix4x4 projection, UnityEngine.Texture atlas) (at C:/buildslave/unity/build/Modules/UIElements/Renderer/UIRenderer/UIRenderDevice.cs:824)
UnityEngine.UIElements.UIRRepaintUpdater.DrawChain (UnityEngine.Rect topRect, UnityEngine.Matrix4x4 projection) (at C:/buildslave/unity/build/Modules/UIElements/Renderer/UIRRepaintUpdater.cs:218)
UnityEngine.UIElements.UIRRepaintUpdater.Update () (at C:/buildslave/unity/build/Modules/UIElements/Renderer/UIRRepaintUpdater.cs:190)
UnityEngine.UIElements.VisualTreeUpdater.UpdateVisualTree () (at C:/buildslave/unity/build/Modules/UIElements/VisualTreeUpdater.cs:70)
UnityEngine.UIElements.Panel.Repaint (UnityEngine.Event e) (at C:/buildslave/unity/build/Modules/UIElements/Panel.cs:589)
UnityEngine.UIElements.UIElementsUtility.DoDispatch (UnityEngine.UIElements.BaseVisualElementPanel panel) (at C:/buildslave/unity/build/Modules/UIElements/UIElementsUtility.cs:240)
UnityEngine.UIElements.UIElementsUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at C:/buildslave/unity/build/Modules/UIElements/UIElementsUtility.cs:78)
UnityEngine.GUIUtility.ProcessEvent (System.Int32 instanceID, System.IntPtr nativeEventPtr) (at C:/buildslave/unity/build/Modules/IMGUI/GUIUtility.cs:179)
Obi appears to be completely unusable in 2019.1 for me.
