08-09-2017, 05:53 PM
Hello there, so we're running into an issue as well when disabling the ObiRope component and enabling it.
This is very easy to recreate and doesn't require any custom code
1. Create a plane and add an Obi Collider to it
2. Create a rope (you can use the rope prebuilt menu)
3. Position the rope above the plane
4. Pin one of the ropes ends so that the rope will hang down onto the plane
5. Press play and wait until the rope is draped against the plane
6. Disable the rope
7. Re-enable the rope - you will see that the rope falls through the collider and gets stuck inside the plane
This isn't mission critical for us yet, but we are disabling ropes as a performance optimization so we will need a fix to this issue eventually. Thanks!
6. Disable the rope
