Bug / Crash  Late Update,that two or more solvers can't work in this mode at the same time,
Hello, I found a problem,“Simulation Order: Late Update”,
 that two or more solvers can't work in this mode at the same time, and this is necessary for quick action. If only a single solver is used, it can not be assigned to a collision object separately, and it is hoped to be solved at an early date.
This is a video showing BUG
https://www.bilibili.com/video/av20503797/
Hey, I'm having the same problem :
That's actually weird because everything was working great, unity crashed (not because of obi I think, I made some changes in play mode on a non obi script and it crashed at this moment) and since the crash i'm having the issue  Indeciso So I don't really know how to make a repro for this one.
I made some tests on a blank project, and I suppose somehow when unity crashed, the bug just moved on my main character, thats why I did not noticed it (it was present, but on other solvers)
I made a repro on a blank project ! Using Unity 2017.3.0p1. Jose, i'm sending you this in private.
