Help  Cable jitters when extending and reducing cable lengths
So I am controlling the position of an object attached to 4 cables (Scene shown below).
When giving control to all the cable to move the robot. Sometimes the cables jitter continuously.
(check the video in the link below)
https://drive.google.com/file/d/139fZwr1...sp=sharing
I am using the following parameters.
# Rope Blueprint (same for all cables):
Thickness = 0.05
Resolution = 0.05
Pooled particles = 200
# All cables:
Substeps for Obi Fixed updater = 70
Obi Solver:
The code to control the cable lengths is given below.
Control_c1#.cs -----
using System;
using System.Collections;
[RequireComponent(typeof(ObiRope))]
public class Control_C1 : MonoBehaviour
    public ObiRope rope1;
    public ObiRopeCursor cursor1;
    public float rope_c1;
    public float rope_c1_rest;
    public float minLength = 0.1f;
    //public float speed = 1;
    public float cable_threshold = 0.02f;
    public float time_dt;
    public float cable1Velocity;
    public float velocityConstant = 1.0f;
    public float c1_control_ip;
    public TCPListenPipe listenerScript;
    // Use this for initialization
    void Start ()
        rope1 = GetComponent<ObiRope>();
        cursor1 = GetComponent<ObiRopeCursor>();
        listenerScript = FindObjectOfType<TCPListenPipe>();
        time_dt = Time.deltaTime;
    // Update is called once per frame
    public void Update()
        rope_c1 = rope1.CalculateLength();
        rope_c1_rest = rope1.restLength;
        c1_control_ip = listenerScript.c1_action;
    // Function to get current length of cable 1
    public float GetCable1CurrentLength()
        return rope_c1;
    // Function to get rest length of cable 1
    public float GetCable1RestLength()
        return rope_c1_rest;
    // Function to determine variable cable input velocity
    public float GetCable1Velocity(float length, float control_ip)
        float c1_control_ip = control_ip;
        float c1_len = length;
        cable1Velocity =  velocityConstant * (c1_control_ip - c1_len);
        return cable1Velocity;
    // Function to set cable 1 control input with variable velocity
    public Action SetCable1(float length, float control_ip, float velocity)
        float c1_vel = velocity;
        return () =>
            if (c1_len > c1_control_ip + cable_threshold)
                cursor1.ChangeLength(c1_len - c1_vel * time_dt);
            else if (c1_len < c1_control_ip - cable_threshold)
                cursor1.ChangeLength(c1_len + c1_vel * time_dt);
            else if (c1_len == c1_control_ip - cable_threshold)
                Debug.Log("Current Length and Control input are the same for Cable 1");
                return;
Control_main.cs -----
//|Method to control all cables parallely
    public void set_control()
        var CableParams = paramScript.allParams.Cable;
        var Control = paramScript.allParams.Control;
        var Velocity = paramScript.allParams.Velocity;
        if (Velocity.c1_vel!= 0 && Velocity.c2_vel!= 0 && Velocity.c3_vel!= 0 && Velocity.c4_vel!= 0)
            // Setting control with variable velocity
            Parallel.Invoke(c1Script.SetCable1(CableParams.Cable1, Control.c1_control_ip, Velocity.c1_vel),
                            c2Script.SetCable2(CableParams.Cable2, Control.c2_control_ip, Velocity.c2_vel),
                            c3Script.SetCable3(CableParams.Cable3, Control.c3_control_ip, Velocity.c3_vel),
                            c4Script.SetCable4(CableParams.Cable4, Control.c4_control_ip, Velocity.c4_vel));
        // Checking applied control and setting the action_completed status
        if (Control.c1_control_ip!= 0
            && Control.c2_control_ip!= 0
            && Control.c3_control_ip!= 0
            && Control.c4_control_ip!= 0
            && Math.Abs(CableParams.Cable1 - Control.c1_control_ip) < 0.2f
            && Math.Abs(CableParams.Cable2 - Control.c2_control_ip) < 0.2f
            && Math.Abs(CableParams.Cable3 - Control.c3_control_ip) < 0.2f
            && Math.Abs(CableParams.Cable4 - Control.c4_control_ip) < 0.2f
            && Math.Abs(CableParams.Cable1_rest-CableParams.Cable1)<0.05
            && Math.Abs(CableParams.Cable2_rest-CableParams.Cable2)<0.05
            && Math.Abs(CableParams.Cable3_rest-CableParams.Cable3)<0.05
            && Math.Abs(CableParams.Cable4_rest-CableParams.Cable4)<0.05)
            if (action_completed == 0.0f)
                action_done = 1.0f;
                action_status = "completed";
                //Debug.Log("Action Status: " + action_status);
                action_completed = 1.0f;
The variable velocities for all cables and the cable control inputs are received from python using a TCP connection.
Any advice or suggestion is greatly appreciated.
(16-05-2023, 07:57 AM)rohit_dhak Wrote: Hello,
Thickness = 0.05
Resolution = 0.05
# All cables:
Obi Solver:
using System;
    void Start ()
        return rope_c1;
        return () =>
                return;
                action_done = 1.0f;
Both your settings and your code look correct to me. Would it be possible to share your scene/project so that we can take a closer look, by sending them to support(at)virtualmethodstudio.com? thanks!
(16-05-2023, 08:45 AM)josemendez Wrote: Hi,
I'm refactoring the code on python side.
Will send it by today or by latest tomorrow.
Thank You.
(16-05-2023, 09:07 AM)rohit_dhak Wrote: I'm refactoring the code on python side.
Thank You.
So I have sent all the files and necessary information on Virtual Method Support <support@virtualmethodstudio.com>
Please have a look and let me know if you need any more information.
Thank You.
I am not sure if you received the mail where I sent the information regarding the cable jitter issue.
I am still awiting a reply.
Thank you.
(05-06-2023, 08:33 AM)rohit_dhak Wrote: Hello,
Thank you.
Hi Rohit,
Received your message, haven't had time to look at it yet. Will do so asap and get back to you shortly.
(07-06-2023, 11:34 AM)josemendez Wrote: Hi Rohit,
what was the resolution? I'm lifting a cable that is scooped up with robot arms (rope is resting in the elbow area... and it jitters and bounces when I lift and shift, even going slow.
