07-02-2023, 09:35 PM
Hello
I had problems with the rope and its connection to the object.
I have an item - a fishing rod. It consists of bones connected by a "Configurable Joint". When I connect the rope to the last bone I get this
If you connect this rope to another object, then everything is fine.
Tried the solution described here http://obi.virtualmethodstudio.com/forum...age-3.html.
But the result is not perfect. One particle in place, and the rest went down again
Here are screenshots of rope and object settings
Help is needed! Thank you
