Help  Clothing implodes on itself
Hello there, I recently bought Obi Cloth to use in my project for a character creation tool. I have followed the tutorial you guys have posted on your YouTube channel:
https://www.youtube.com/watch?v=usXaFr6N630
My main issues is that after following the tutorial step-by-step, my shirt just implodes on itself. I have tried different skin parameters combinations in the blueprint editor but the problem persists. I do not have any personal scripts running, I made a new project to test out Obi Cloth and only imported the necessary stuff. Any ideas what might be causing this? I'm also not sure what other information I should give out, so help is appreciated there as well. Thank you in advance.
(19-11-2021, 05:47 PM)ElDonte Wrote: Hello there, I recently bought Obi Cloth to use in my project for a character creation tool. I have followed the tutorial you guys have posted on your YouTube channel:
This is usually a symptom of scaling issues. Make sure the scale of your mesh matches the blueprint. Easiest fix is making sure your scale values are 1,1,1 on the cloth transform.
There’s also a possibility that your mesh was exported without scaling applied. See:
https://m.youtube.com/watch?v=5j7k_tJUSJc
