Help How to set Obi Shape Matching Constraints - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Help How to set Obi Shape Matching Constraints (/thread-942.html) |
How to set Obi Shape Matching Constraints - suntabu - 28-02-2019 Hi, as said in title. Is there any demo scene to show me how to use this constraint? I've tested many times, but it did not work at all. I just wanna use it at the Sample Scene - ClothSoftBody on a ball. RE: How to set Obi Shape Matching Constraints - josemendez - 28-02-2019 (28-02-2019, 11:02 AM)suntabu Wrote: Hi, as said in title. Shape matching constraints are included for compatibility with Obi Softbody (a separate asset). They are not used for cloth at all. They intended use case is volumetric elastoplastic soft bodies. RE: How to set Obi Shape Matching Constraints - suntabu - 01-03-2019 (28-02-2019, 11:27 AM)josemendez Wrote: Shape matching constraints are included for compatibility with Obi Softbody (a separate asset). They are not used for cloth at all. They intended use case is volumetric elastoplastic soft bodies. Hi, thanks for your reply. I've purchased Obi-Cloth on Asset-Store for creating a Slime-like game. I've set up all I can do, but the slime does not recover to original shape at all, it should recover some. Please check the video.https://youtu.be/gFosttYJOGs RE: How to set Obi Shape Matching Constraints - josemendez - 01-03-2019 (01-03-2019, 01:50 AM)suntabu Wrote: Hi, thanks for your reply. Make sure the particles at the edges of the cloth are fixed, so they're not dragged away. They should offer some resistance. Then, just make sure the amount of distance constraint iterations used is enough. For slime, the standard low iteration count should be enough. You might even have to reduce stiffness for things to works better. Here, I recorded a video of the full setup for you: RE: How to set Obi Shape Matching Constraints - hungkhmt2k4 - 30-09-2019 (01-03-2019, 08:00 AM)josemendez Wrote: Make sure the particles at the edges of the cloth are fixed, so they're not dragged away. They should offer some resistance. Then, just make sure the amount of distance constraint iterations used is enough. For slime, the standard low iteration count should be enough. You might even have to reduce stiffness for things to works better. Slime did'nt work when move mouseĀ ! Please help me! |
