Help how to remove fixed state - Printable Version +- Obi Official Forum (https://obi.virtualmethodstudio.com/forum) +-- Forum: Obi Users Category (https://obi.virtualmethodstudio.com/forum/forum-1.html) +--- Forum: Obi Cloth (https://obi.virtualmethodstudio.com/forum/forum-2.html) +--- Thread: Help how to remove fixed state (/thread-901.html) |
RE: how to remove fixed state - josemendez - 14-02-2019 (14-02-2019, 12:47 PM)Richard Wrote: I want it be static. Hi, That code does not make sense at all. - You're assigning a string to a variable of type GameObject. The name of an object is not the object itself. - "actor" must be an ObiActor component, not a GameObject. - "solver" must be declared somewhere in your script, and must be of type ObiSolver. You can make it a public variable and assign it in the inspector, or grab it from the actor itself. Imho, before trying to use advanced stuff like cloth simulation, you should first study the elemental stuff: how to write C# and how to use Unity. I cannot hand-hold you trough such basic coding issues. Here's some resources on the topic: https://unity3d.com/es/learn/tutorials/s/scripting RE: how to remove fixed state - Richard - 14-02-2019 (14-02-2019, 12:55 PM)josemendez Wrote: Hi, It is not imho. I learned some, but not enough. I should study basic and after ask you. Thank you. I check tutorial for what I do not have now. RE: how to remove fixed state - Richard - 14-02-2019 (14-02-2019, 01:03 PM)Richard Wrote: It is not imho. I learned some, but not enough. I should study basic and after ask you. Thank you. I check tutorial for what I do not have now. Hello. I learned a little. In the website(http://obi.virtualmethodstudio.com/tutorials/scriptingparticles.html), I think you do not declare "solver". How did you declare in that script? RE: how to remove fixed state - josemendez - 14-02-2019 (14-02-2019, 04:05 PM)Richard Wrote: Hello. I learned a little. Hi there, The code in most snippets assumes the solver/actor are already declared. Unless the sample code is an entire script, it is assumed these variables come from your own code. There's many ways to get a reference to a solver. If you already have an actor, you can obtain the solver that manages it: Code: ObiSolver solver = actor.Solver; You can also declare a public variable in your script, and fill the reference from Unity's inspector: Code: public class YourScript : MonoBehaviour That's just two possibilities. Being a variable, you can declare a variable of type ObiSolver anywhere in your code and fill it from anywhere you want. As long as you respect C#'s syntax, that is. RE: how to remove fixed state - Richard - 14-02-2019 (14-02-2019, 04:18 PM)josemendez Wrote: Hi there,Hello. I really appreciate your hints. I think I could make one. Is it perfect? |
